StevenOrbi
Jan 21, 2020Tutor
ORBI RBK43 RBR40 Router ring blinking white
Have the RBK43 model which contains the RBR40 router and 2 RBS20 satellites. Occasionally, the admin page and IOS app cannot connect. Usually a reboot of the RBR40 resolves.
Yesterday, this occurred and a reboot of the router just hangs at the flashing white light. I tried the factory reset but it continues in the white blinking light loop.
Found posts on manually loading firmware using tftp and followed those instructions closely but could never actually upload the firmware.
Any help would be appreciated as the units are about 18 months old and hate to replace the whole system.
What is the Mfr and model# of the ISP modem the NG router is connected too?Power OFF the ISP Modem AND Orbi system for 30 seconds. Then power ON the modem and let it sync. Then power ON The RBR and let it sync. Top ring LED should eventually turn OFF. If it does, power ON the RBSs.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).- SsID is not available. Can’t figure out how to hardwire to router to even login.
Have tried setting a static ip on PC and connecting to router but no success.- FURRYe38Guru - Experienced User
Is PC LAN cable connected to the RBR? If so, it should get a 192.168.1.something address. The web page for the RBR is at 192.168.1.1 or orbilogin.com.
You may need to factory reset the RBR and setup from scratch.
Please give feedback about the ISP modem as well...Maybe causing problems here.
