neukenuk
Jul 20, 2018Aspirant
Orbi RBK50 AC3000 and Sony KD-55X9005C Disconnects
Hi. I bought the RBK50 which arrived yesterday to replace R6120 which i had been having problems with with devices dropping on and requiring restart starting monthly then becoming weekly for absolute...
Aug 15, 2018Guru - Experienced User
Possible issue with the TV and how it handles the wifi signal and connection and or this application you use. I would make contact with the Mfr of the TV and an this application. If other devices are working ok accept for the TV and this application, I would presume there maybe a issue with the TV and this application...
- neukenukAug 15, 2018AspirantYes. Still doesn't explain how the TV handles WIFI differently when connected to the Router compared to that when connected Satellite.
There does seem to be a theme
https://community.netgear.com/t5/Orbi/Orbi-RBK50-and-Sony-Smart-TV/td-p/1325067- FURRYe38Aug 15, 2018Guru - Experienced User
Something to present to the TV mfr about...They may have more information or should be made aware of this.
