neukenuk
Jul 20, 2018Aspirant
Orbi RBK50 AC3000 and Sony KD-55X9005C Disconnects
Hi. I bought the RBK50 which arrived yesterday to replace R6120 which i had been having problems with with devices dropping on and requiring restart starting monthly then becoming weekly for absolute...
Aug 15, 2018Guru - Experienced User
Possible issue with the TV and how it handles the wifi signal and connection and or this application you use. I would make contact with the Mfr of the TV and an this application. If other devices are working ok accept for the TV and this application, I would presume there maybe a issue with the TV and this application...
neukenuk
Aug 15, 2018Aspirant
Yes. Still doesn't explain how the TV handles WIFI differently when connected to the Router compared to that when connected Satellite.
There does seem to be a theme
https://community.netgear.com/t5/Orbi/Orbi-RBK50-and-Sony-Smart-TV/td-p/1325067
- FURRYe38Aug 15, 2018Guru - Experienced User
Something to present to the TV mfr about...They may have more information or should be made aware of this.
