newhall523's avatar
newhall523
Orbi RBK50 constantly dropping internet
Hello all, hoping I can get some help.  I work from home, so depend on reliable internet connectivity.
I bought this almost a year ago, but installed/set it up about 8 months ago.  During that time, no major issues.  Sporadic disconnection from internet for a minute or so, but always reconnected (annoying, but not a big enough deal to create a post here).  This would happen a few times a month.  Updated firmware a few times as updates became available.  After one update a few months ago, all the personal settings got wiped and I had to do personal settings all over again.  Annoying, but after doing that, it worked like it had been over the prior months.
Now:  Until last night, it was working as it had over the past 8ish months. I was streaming hbo until about 11pm, no problems.  This morning, i woke up about 6:30ish and the magenta ring was lit.  I unplugged and re-plugged and it did not reconnect.  I turned off everything (cable modem, orbi) for a couple minutes.  Powered up modem and let it cycle, then orbi, and internet was back on.  Yay!  then, less than 10 minutes later, internet connection dropped.  Modem still showed internet connection.  I've repeated this process/cycle about 10 times today, all with the same result: connects for 5-10 minutes, then drops internet.  But it still shows the network, and devices are still connected to the network.
I tried factory reset, but interestingly, it didn't work.  I used a paper clip, the little power light blinked orange/amber, but all my settings remained.  Tried setting up new device in app, but the default orbi setup wifi ssid never showed up.  I tried this 3x...not sure what I'm doing wrong.    Thank you in advance for your help.
What Firmware is currently loaded?  v2.3.5.30
What is the Mfr and model# of the ISP modem the NG router is connected too? Arris TG1672G
Is the Orbi system operating in Router or AP mode? Router
What is the size of your home? Sq Ft? 1600
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected. approx. 35ft
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. 2.4g: Auto; 5g: 48
Any Wifi Neighbors near by? If so, how many? Yes, 10 or so
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Not using Armor or Circle; have not tried other settings
  • FURRYe38's avatar
    "What is the Mfr and model# of the ISP modem the NG router is connected too? Arris TG1672G"
    What mode is the ISP modem running in? Modem or Router? This is a modem with built in router and wifi.
    This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    We presume the magenta ring is on the RBR?
    • newhall523's avatar
      newhall523
      Thanks for the quick reply. I will try your suggestions. What frustrates me is that it was working fine before over the past 8ish months. What happened literally over night?
      The box and online ad said rbk50, but the ring is magenta. Not sure.
      • FURRYe38's avatar
        The RBR is the RBR50 with in the box. Just making sure which ring you were referring too. The RBR which is the base router or the RBS which is the satellite.
        Let us know about the suggestions.
