johnny0206's avatar
johnny0206
Follower
Sep 02, 2020
Orbi RBK50 Switching AP mode then no internet
I login Orbi admin then misstakenly switch it to AP mode, then the internet is down. And couldn't connect to Orbi wifi and the login web to switch it back.
was following this youtube: https://www.youtube.com/watch?v=H7LOcJ8GdDo&t=3s
How to reset it? thanks
    If you switched your Orbi to AP mode before switching your router, you now have no DHCP server.
    You can plug into the Orbi router and log in and change it back to router mode.
  • FURRYe38's avatar
    Press the reset button on the RBR for 15 seconds then release. Wire connect a PC or laptop to the RBR and use a web browser to walk thru the setup wizard.
  • Did you ever get this solved. I just did the same thing and can't figure out how to change it back.
