lawnmowerman's avatar
Mar 18, 2020
Orbi RBK50 WiFi going offline
My Orbi RBK50 wifi connection is constantly going offline, while wired connection stays active. So all my wireless devices suddenly go offline. The only way to fix has been to reboot the router. I have done this several times already and not sure what's going on.
This is the first time I've seen this issue in a couple of months since I started using this router.
I am on firmware v2.5.1.8, since that's the last version that supports Disney Circle.
Anybody else having this issue and have any suggestions to fix it?
Thanks
  • Can you narrow down if the issue started when you upgraded to 2.5.1.8?
    There is the standard, reset your satellites and router and reconfigure.
    You can also try downgrading to 2.3.5.30 to see if stability returns.
    • I have been on v2.5.1.8 for over a month, so it did not start with that.
      It's not an issue with the Router-Satellite connection, it's all devices losing WiFi suddenly and only a reboot fixes it. This started happening today. Meanwhile, all the wired connections work fine while the wifi is offline.
      Is v2.3.5.30 the last stable version for this router and does Circle work with it?
      Thanks
      • FURRYe38's avatar
        Guru
        Has a factory reset and setup from scratch been performed since last update? You might try this first. Don't enable Circle just yet. See if anything changes. If it's better, then enable Circle. Others have need bad behavior with Circle.
        Please give feedback to the other questions as well.
  • 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
    Thanks
    • lawnmowerman's avatar
      lawnmowerman
      Guide
      The distance between the router and the satellite is less than 30-feet since the day I installed it. All other settings are default, and it's been working fine for a few months. Why would the wifi start suddenly stop working when nothing else was changed?
      Thanks
      Thanks
  • Having the same issue now for a couple of weeks. I just did a hard reset and circle still blocks all internet traffic.
      lawnmowerman
      Guide
      I disabled Circle and the WiFi has been okay the past couple of days. Would still like to use Circle since I am able to restrict device time for the kids, especially now since they are home all day. Don't want them online at all hours of the day.
      • FURRYe38's avatar
        Guru
        Try setting up IP address reservations for the devices that are being managed by Circle. Then setup Circle and see if the problem re-appears. Others have posted having problems with Circle.
        For continued help, support and information about Circle, please post in the Circle forum:
        https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
        Good Luck.
