Xx-Shadowz-xX
Feb 06, 2022Aspirant
ORBI RBK50
Recently I purchased the ORBI RBK50. It works amazingly good in my home and I love everything about it also works smoothly and fast for my first mesh wifi setup. I know the kit comes with one router a...
michaelkenward
Feb 07, 2022Guru - Experienced User
Xx-Shadowz-xX wrote:
If I was to buy another kit RBK50 I would keep the new kit router RBR50 as a spare backup just in case or sell it and then use the satellite from that new kit to extend my coverage at home will that work perfectly fine?
The new satellite will not be tied inexorably to the new router, but there may be other Orbi satellite options than the RBS50.
One question that comes up here is about using the router as a satellite. The answer is no.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Xx-Shadowz-xX
Feb 07, 2022Aspirant
Yes please switch this topic to the right section in the forums I am sorry about this didn’t know till right. Thank you for that and all your help I appreciate it with all the information you have given me to go on to look for any support or information related to my new device. I didn’t know NETGEAR completely stopped that I was surprised to see that no manual or similar came with the box lol
