kwonkor's avatar
kwonkor
Orbi RBR 50 no internet connection
My orbi worked find till yesterday, and todat just it died with no reason.
I can connect the internet through the modem to pc directly, but If I plug the cable modem to orbi and to pc then no signal.
Thank god I have spare old router to use for now and still works as a router.
Do you guys think my orbi died? or Is there any way to fix it? It's been over 17 months using this orbi, so warranty is expired.
Is orbi usually dead after a year of use? it seems since warranty is only one year.
  • FURRYe38's avatar
    What FW is currently loaded?
    Have you tried a factory reset on the Orbi router then walk thru the setup wizard?
    Can you still access the routers web page?
    Is the top LED giving any color indication?
    • kwonkor's avatar
      kwonkor
      It's v2.2.1.210
      I'm using Arris SB6183 modem with xfinity.
      I have clicked reset button twice and giving me steady white color LED. If I do the troubleshoot on window, it keeps blinking white. No purple.
      I have not tried to go into routers webpage. shoud I?
      • kwonkor's avatar
        kwonkor
        If i try to log in to 192.168.1.1, it keep checking the intetnet connection and ask me to re-connect
