Sovby's avatar
Sovby
ORBI RBR 50 V2 Loses Ethernet connection
Ive been using this router for 3 or 4 months with everything working fine, but a few days ago it started giving me problems. i lose my ethernet connection to my windows 10 computer. It says ip address is invalid. i can still use wifi on other computers although yesterday even that went out too. i have a intel i7 processor with 32 gb of ram running windows 10. the orbi mesh system is the RBR50v2. i have the xfinity modem plugged into the yellow port that says internet.the windows computer is plugged into another ethernet port on the router. i thought i had fied this yesterday by reconfiguring the router with the orbi app. it was working fine but now no ethernet connection.
  • plemans's avatar
    What xfinity modem is it connected to?
    What firmware version are you on?
    • Sovby's avatar
      Sovby
      The xfinity modem is CGM4140COM. Here is what i found on xfinity website.
      • Model Numbers: TG3482G and CGM4140COM
      • Friendly Model Name: XB6
      • Gigabit Ethernet Ports: 2
      • Dual-Band WiFi Option: Yes
      • 2.4 GHz Connected Client Limit: 30
      • 5 GHz Connected Client Limit: 75
      • Maximum Data Throughput: 1 Gbps
      • WPS (WiFi Protected Setup): Yes
      • Gateway/ Network Management Tool (http://10.0.0.1): Yes
      • Xfinity xFi Eligible: Yes
      • Xfinity xFi Advanced Security: Yes
      • Xfinity app Activation: Yes
      • Two Total Telephone Ports: Yes
      • Battery Backup Capability (Xfinity Voice Only): Yes
      • Link Cordless Phones (CAT-iq 2.0*): YesHome Hotspot Capable: Yes
      • Compatible with Xfinity Home Pro Protection: Yes
      • Compatible with Xfinity Home Self Protection: Yes
      The download speed was 106mbps and the upload speed was 23.2 mbps using wifi. I'm not sure how to see the firmware. i googled it and it said to put in username & password. Im not a network administrator or anything but that doesnt sound very secure. is there a better way to see this? i'm using the netgear router so xfinity turned on briging i think its called?
      • Sovby's avatar
        Sovby
        i also have a 8 port netgear GS308E Smart managed Plus switch.
