rblades
Nov 14, 2020Initiate
Orbi RBR20 regular disconnects
Hello, I have the above Obri Router. For the past 11 months, it has worked great. Our internet service provider installed a new modem and since then every day I need to reset the Orbi (unplug, wait 30 seconds, plug back in). Then it works find for about 24 hours.
Firmware version is: V2.5.1.16
Our cable modem is an Arris model:TG3452.
Any troubleshooting ideas are welcome. Thank you!
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
https://kb.netgear.com/30187/How-to-fix-issues-with-Double-NATCouple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the
