JulietFalcon
Nov 10, 2020Aspirant
Orbi RBR20 slow upload speed
I have a 300 mbps internet service plan with Xfinity and am having issues maintaining proper upload speeds when I run speed tests. My download speeds are typically between 250-350 mbps, and upload speeds between 10-12 mbps. Currently, my download speeds are relatively normal, however, my upload speeds are between 0.5-2 mbps.
I've had this issue in the past and it ended up being because there was a firmware update for my router. I have downloaded and installed the most recent firmware for the RBR20 router (v2.6.1.36) along with my RBW30 satellite (v2.6.1.6). I've continued to run speed tests after the fact and still cannot obtain an upload speed greater than 2 mbps.
This is causing my internet connection to be very slow, especially with my kids gaming systems. Does anyone have any recommendations on how I can bring my upload speeds back to the 10-12 mbps range?
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Is Armor or Circle enabled on the RBR>?
- JulietFalconAspirant
The modem manufacturer and model is Arris Surfboard SB6183. I am unsure how to check if armor is circle is enabled.
Once the update to firmware v2.6.1.36 was complete, resetting the modem and router seemed to fix our problems for the past couple weeks, but here we are again. Download speeds are fine, but upload speeds are back to 0.5 - 2mbps.
If you have Armor enabled, it wil be on your mobile Orbi app and also appear on the RBRs web page as enabled on the first page if you look at the RBRs web page with a web browser.
JulietFalcon wrote:I have a 300 mbps internet service plan with Xfinity and am having issues maintaining proper upload speeds when I run speed tests. My download speeds are typically between 250-350 mbps, and upload speeds between 10-12 mbps. Currently, my download speeds are relatively normal, however, my upload speeds are between 0.5-2 mbps.
Your Orbi upload speeds should certainly be higher and close to your 10-12 mbps. Try the community faq to first narrow down whether the upload speed loss is from the Orbi, wireless and/or wired, etc.: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1984305/highlight/true#M7944
- vajimMaster
Was your slowdown before or after your fw update?
