RJGMarsden
May 06, 2020Follower
Orbi RBR20
Hi,
I have purchased the above router and have been experiencing slow connection when using some Apps (Gmail, Drive, YT, Search). sometimes to get connection I turn the wifi off then back on again on the device. Everthing else works fine, I can do a speed test with good results
I have tried the obvious and rebooted everything however still get this issue on more than one device only when going through the router at home.
Has any body else had this issue? Many thanks in advance
I am running
App version 2.5.1.2
Firmware Version V2.3.5.30
1 Reply
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Modem Combo Units: https://community.netgear.com/t5/Cable-Modems-Routers/What-s-the-Difference-Between-a-Cable-Modem-and-Cable-Modem/m-p/1864698#M21950
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopYou may want to update FW as well:
