CaboBon's avatar
CaboBon
Orbi RBR20
I have had an Orbi router and 1 satellite for 2 years. Out of the blue, last night my Iphone lost connection to the Orbi network. I have tried everything to reconnect and have not had any luck.Help please...any suggestions. My phone is not recognizing the system. I have plugged, unplugged, got rid of the app, reinstated it, cleaned cache,
  • FURRYe38's avatar
    Does a wired PC and web browser connect to the RBRs web page?
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
  • Does your iPhone recognize other wireless networks and can you successfully log in to one of them?  Do you have any other wireless devices at home that can or cannot connect via wifi to your Orbi? I think you covered this but did you try “Forget This Network” in your iPhone and then attempt to reconnect?
    • CaboBon's avatar
      CaboBon
      Hi yes I did do the Forget this network think, and my Iphone has connected to another network.  All other devices have been and are still connected to the Orbi network.  My phone was too until it stopped.  I have tried numerous times to get it to connect back but no luck.  I will likely try to reset it to see if that works.  I have been reluctant to do that because I have Arlo cameras set on the network.  Would really be unhappy if I caused a bigger problem.
      Thanks
      • FURRYe38's avatar
        As long as you use the same SSID name and password for the wifi, your wifi devices will reconnect on there own.
