Uruk
Apr 27, 2018Tutor
Orbi RBR40 - Schedule not working
Hi,
Since I updated the router firmware 2.0.0.56 to firmware 2.1.2.18, the schedule no longer works.
Previously, it was configured to turn off every day at 00:30 and to turn on at 07:00.
Since the change:
1 - I can not access the configuration (the page is no longer editable),
2 - and moreover the wifi does not go out anymore.
My versions are: RBR40: V2.1.2.18 + RBW30: V2.1.3.6
In a previous discussion another user had the same problem but with firmware V1.12.0.20 but no solution was available.
Can Netgear offer a solution?
Thanks
Thank you FURRYe38 for the link to this discussion.
My RBR40 system finally received yesterday (2018-04-28) a new automatic update to version V2.1.4.10.
The update alone did not correct the problem of the non-editable schedule. In addition, it was necessary to perform a factory reset for the calendar to be editable again.
Now everything is working properly.
- DarrenMSr. NETGEAR Moderator
Hello Uruk
I would check for updated on the RBR40 as it should be 2.1.3 and check if that page is still greyed out.
DarrenM
- UrukTutor
Thank you Darren for your prompt response.
According to Netgear support search results pages, the most recent version for RBR40 is 2.1.2.xx.
Do you have any information about the version 2.1.3.xx release date for RBR40?Thanks in advance.
Get 40 series FW from here:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/td-p/1533584/page/29
- UrukTutor
Now everything is working properly.- FURRYe38Guru - Experienced User
Glad its working after the update. Enjoy.
