Slapshot88's avatar
Slapshot88
Orbi RBR40 Disconnect
I have one RBR40 and three additional satellites. This has been running flawlessly for a few years. Recently we have been having issues in that the ORBI disconnects from the modem. Now, it has disconnected and, after following all of the directions I have found online, we cannot reboot it, reconnect it, and recently no longer can reset my password. Do these routers just go bad over time? If so, that is disappointing.
Not certain what to do
  • plemans's avatar
    Routers can go bad. Doesn't mean yours has though.
    Whats the router actually doing? (led's, ping, etc)
    • Slapshot88's avatar
      Slapshot88
      Most of the time the LED is either flashing white, or no light at all. When trying to access via the ORBI app I constantly receive the message “trying to reconnect” or “We can’t find your ORBI”
      • plemans's avatar
        what happens if you hardwire a pc/laptop into the orbi?
        Are you able to access it?
        What modem/gateway are you connecting it to?
