Willam11
Apr 13, 2020Initiate
Orbi RBR40 Flashes (not pulsates) white frequently
Hi,
I bought a refurbished Orbi RBR43 kit and set it up 4 days ago. It is sitting behind a comcast modem/router combo plugged into the ethernet port.
Serial #: 50U77953005A2
Firmware version: V2.3.5.32
Since yesterday, it will drop wifi completely and flash white until i power cycle it.
There is no mention in the documentation on what flashing white means. It is not pulsing, I have seen it pulsing. This is flashing.
If I pull the ethernet cable out of the back and into my computer, the internet works fine. This would also not explain the dropped wifi signal.
I have tried messing with the channel settings and turning off/on different features like Fast Roaming and MU-MIMO to no avail.
What does the flashing white mean? Is this a network configuration error that I can remedy?
Thanks for the help,
Will
Rant below:
This entire experience, especially with lack of documentation and atrocious customer support has been very frustrating. I'm wondering if I should just jump ship now.
I tried contacting customer support, and was greeted with an all too common script-slinger that spent 40 minutes to figure out that they cannot help me unless i register my product (what?) and that my product has already been registered to someone else.
When I got the Orbi it had not been factory reset, so I am wondering if it was refurbished at all.
wtf, netgear?
IWhat mode is your modem router working in? Bridge or Router mode? If it has a built in router, This would be a double NAT condition which isn't recommended. Would be a cause of the RBR flashing WHITE possibly.
https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- Willam11Initiate
Thank you, 10/10 advice. I plan to do that in a bit.
For anyone else experiencing this issue, it can also be resolved by setting a reserved IP address for the Orbi.
I understand comcast can sometimes block you from enabling bridge mode, for example if you are using xFi features, so setting a reserved IP might be some peoples only option.
Once I set a reserved IP for the Orbi from my comcast router web control, I no longer have Wifi drops / flashing white light.
Thanks, @Blanca_O ! I will definietly be turning the Comcast router/modem into bridge mode.
Ya, some ISPs block user access to there modems. Glad you were able to get your working.
Enjoy. :smileywink:
