Shahab's avatar
Shahab
Apprentice
Apr 21, 2020
Orbi RBR40 WiFi disconnects daily
Hi everyone, My Connection: Arris TM1602 Cable Modem (Charter) -> Orbi RBR40 router -> 2 RBW30 Satellites Looking to get help with my Orbi system as I am experiencing my WiFi dropping daily, often multiple times a day. This has been going on for almost a month now. My initial issue was that DNS wasn't working properly, it wouldn't resolve hostnames. That issue was possibly related to Circle being enabled on my system. I had issues updating firmware on my system, so Netgear did a RMA on the router and one of the satellites. After I got the new system, I updated the firmware on both the router and satellites, even though they were current, then did a factory reset per Netgear Level 1 support troubleshooting. With my new system, the problem changed to the connection dropping altogether. I have verified that my internet connection via Charter isn't the issue by connecting directly to the cable modem when my wifi connection drops. I have had a support case open with Netgear for almost a month now dealing with this issue and they have finally escalated the issue to their engineering team. The engineering team finally got back to the Level 1 and said that the issue seemed to be with the satellites and they gave me a beta firmware to install on the Satellites. They also wanted me to update the router to the latest firmware version and then do another factory reset. I did all that and still have the same issues. I have run several packet captures from the Orbi Debug page and going through the logs myself, found a couple of entries that repeat pretty often. Has anyone else seen these and know what they might mean? FIXME:osif_forward_mgmt_to_app: Event length more than expected..dropping 16.33.12.828163 HYDR bandmon ERR : bandmonMBSAHandleRawMediumUtilizationUpdateEvent: Failed to resolve channel information for channel 157 Model Name Device Name Current Version Router RBR40 RBR40 V2.5.1.16 Satellite RBW30 Orbi Satellite-1 V2.5.0.2 . Satellite RBW30 Orbi Satellite-2 V2.5.0.2
  • FURRYe38's avatar
    • Shahab's avatar
      Shahab
      Apprentice
      • Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected to: Arris TM1602 Cable Modem
      • What is the size of your home? Sq Ft?  I have a 2 story house with a finished basement.  Without the basement, house is 2,500 Square feet
      • What is the distance between the router and satellite(s)?  Router is in the basement, and 1 satellite per floor in the main part of the house
      • What channels are you using? 2.4 Ghz is set to Auto and 5 Ghz is set to 48
      • Any Wifi Neighbors near by? If so, how many? I have 2 neighbors on either side of the house
      • Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings - Already enabled
      • FURRYe38's avatar
          Any chance of you moving the RBR out from the basement? Basements are not idea locations for wifi routers. Concrete and steel in the foundation will impede wifi coverage and performances. What is the distance between the RBR and RBS?
  • CrimpOn's avatar
    CrimpOn
    These messages appear in the Orbi log (the Orbi web interface, Advanced Tab, Admin, Logs)?
  • Did you ever get this resolved? I'm having the same issue and have been for months. I didnt know it was so bad and frequent till this quaritine. Out of all the discussions on this I've only seen 1 resolved and that was a product defect.  All of the other suggestions didnt help anyone.
    I wish I would have caught this during the 1st 3 months , now they want to charge me 90 dollars to do what I assume would be what everyone has described. Its not my internet its this orbi product , I never had these issues before this.
    • Shahab's avatar
      Shahab
      Apprentice
      Hi,
      After more than a month of problems, I was finally able to talk to a supervisor from the 1st level team who escalated the issue to level 2 supervisor, who then likely escalated to Level 3. The level 3 rep then sent me a replacement router, upgrading me to a RBR50 from the RBR40. I had a few disconnects when I first got the RBR50, but for the past few weeks it’s been running without interruption.
      Make sure you have the LAN/WAN packet capture enabled and running from the Orbi debug page. Then when you get a disconnect, save the packet capture (if it’s still running) and send it to Netgear. Try to keep a tally of when the disconnects happen, date and time, what device you noticed it on, etc.
      • guilloryjc's avatar
        guilloryjc
        Thanks for the response.
        What a pain, I have the RBR50 and its happening 2-3 times a day. My 3 months are up and now they want $90 to do what I assume will not help.
        Did you pay or were you covered ?
