goblea
Mar 05, 2020Star
Orbi RBR50 - Backhaul status disconnected
I am having major issues with my Orbi system, I have the RBR50 in AP mode with a static IP along with 3 RBS50's as I have these at each TV location to give me cabled connections to my devices, the sa...
Apr 13, 2020Guru - Experienced User
You might try a factory reset next time:
Good Luck.
Atreides
Apr 15, 2020Tutor
Factory resetting only temporarily fixed the backhaul status which it eventually lost. But did not fix the 20 odd devices connected but missing in Attached Devices. They also did not show up in the Orbi app under the satellites
Downgrade fixed it all for me.
- 2intenseApr 27, 2020Tutor
I am having the same problem as the others. All of my satellites show "disconnected" under backhaul status. I tried factory reset on router and all satellites and they reconnected for a couple minutes and went back to "disconnected". Ugh! Do I need to roll back my firmaware? If I do, then do I also need to turn off auto updates for the firmware? When will Netgear fix this?
HELP...
(RBR50, Firmware Version 2.5.1.8, macOS 10.15.3)
- AnonymousApr 27, 2020
2intense wrote:I am having the same problem as the others. All of my satellites show "disconnected" under backhaul status. I tried factory reset on router and all satellites and they reconnected for a couple minutes and went back to "disconnected". Ugh! Do I need to roll back my firmaware? If I do, then do I also need to turn off auto updates for the firmware? When will Netgear fix this?
HELP...
get rid of 2.5.1.8 and you'll be fine
- FURRYe38Apr 27, 2020Guru - Experienced User
Updat to v16 on the RBS first then the RBR lastly.
Factory reset and setup from scratch after the update.
HELP...
factory resets are for lost passwords
