RikParr73
Oct 12, 2018Aspirant
Orbi RBR50 - Poor Ethernet Backhaul on Satellites
Hi
I have RBR50 and 2 x Satellites. I also have Virgin Media Superhub 3, set in 'Modem mode'. Modem is on static 192.168.0.1 (Unable to change ISP set)
Satellites are connect via ethernet...
Oct 12, 2018Guru - Experienced User
If this is your switch your using, I believe this maybe a managed switch:
https://www.cisco.com/c/en/us/support/switches/sg200-50p-50-port-gigabit-poe-smart-switch/model.html
if so, see if you can find the IGMP proctols with in it's management page. Disable ALL IGMP procols on the switch. Others have reported having problems with Orbi systems and Managed switches. Seem that IGMP protocols maybe the culprit:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1553749/highlight/true#M30673
https://community.netgear.com/t5/Orbi/Using-Router-Configured-as-Access-Point-Cannot-see-Satellites-in/m-p/1612052/highlight/true#M37974
https://community.netgear.com/t5/Orbi/Orbi-Ethernet-Backhaul-with-Managed-Switches/m-p/1613897#M38123
I use non managed switches and have had not problems connecting my satellite via wired back haul.
RikParr73
Yes, it's amanaged switch, I will check the settings and disable if any are active and come back with the result. Many thanks.
- FURRYe38Oct 12, 2018Guru - Experienced User
:smileywink:
- FURRYe38Oct 13, 2018Guru - Experienced User
Let us know how it goes...
- RikParr73Oct 13, 2018Aspirant
Hi
Been away overnight, but back and shortly going into the loft to check the managed switch and will confirm active wired connections to the router and sats. I've notcied that my sonos speakers in close proximity to the sats are not connecting to the respective sat but the router which is further away, is that a sign there is an issue?
Many thanks, Rik.
I believe Sonos Has there own wifi broadcast so having them close to the Orbi devices will be a problem. I would turn OFF the Sonos for a while and test the Orbi system alone and see how it goes.
