AaronLTek
Apr 06, 2020Guide
Orbi RBR50 - VERY SLOW client speeds
I've had this installed for a week or so and I'm seeing VERY SLOW, and VERY INCONSISTANT speeds even with line-of-sight and almost any distance. Please let me know if you've seen this problem, or know a fix. I'm about to give up and get something else.
I've tested several locations but the best example of the problem is this test...
@ 30ft open air, line of sight
Orbi signal strength (PC web page) shows connected on 5Ghz @ 100% signal
WifiMan android app shows 5Ghz @ -59dBm (connected), 2.4Ghz @ -41dBm BUT only shows 14 to 27Mbps speed!
... I've seen speeds as low as 7Mbps, high as 175mbs, usually 45-60 mbps range. Speed Jumps around every few seconds and changes can be drastic but the dBM stays steady between 58 to 60dBm
... same speeds testing with the Orbi app and WifiMan app
Neighbor Houses are spread apart so very little, it any, channel interference. Most channels have no neighbors on at all.
For example, the test above using Wifiman app, only shows 1 SSID on 2.4Ghz at the client location, at -83dBm. No 5Ghz overlaps at all, the only 5Ghz radio is on channel 155 when mine is on 42
Here's my specs...
Hardware Version RBR50
Firmware Version V2.5.1.8
Operation Mode AP
Region North America
2.4G Channel Auto ( 9 )
2.4G Mode Up to 400 Mbps
5G Channel 36+40+44+48(P)
5G Mode Up to 866.7 Mbps
Advanced settings:
Enable Beamforming
Enable Fast Roaming
Enable WMM (Wi-Fi multimedia) settings
- Retired_Member
here's your problem: Firmware Version V2.5.1.8
I still have major problems... I have tried multiple locations around the house, most using Ethernet backhaul. No matter where I try and what settings I try (channel changes, turnig on/off roam and other Advanced settings, etc) it still has the same two issues...
1. Cameras will frequently connect and disconnect, randomly... even though signat there is in the -50dbm range
2. when testing with the Orbi app or Wifi Man app, I'll show great 35-60dbm range all over the house BUT often only get 14-58mbit throughput... while other times I'll get 130-500mbit... in the same spots!
If I put the old ASUS AC68P in the same place as the Orbi in my office I get -38dbm and 866mbit!
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQWhat is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. Channel 9 isn't a primary channel to use. Try Auto as well.
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
AaronLTek wrote:I've had this installed for a week or so and I'm seeing VERY SLOW, and VERY INCONSISTANT speeds even with line-of-sight and almost any distance. Please let me know if you've seen this problem, or know a fix. I'm about to give up and get something else.
Here's my specs...
Operation Mode AP
5G Mode Up to 866.7 MbpsAdvanced settings:
Enable Beamforming
Enable Fast Roaming
Enable WMM (Wi-Fi multimedia) settings- Retired_Member
FURRYe38 wrote:Has a factory reset and setup from scratch been performed since last FW update?
Here's my specs...
Operation Mode AP
Enable Beamforming
Enable Fast Roaming
Enable WMM (Wi-Fi multimedia) settingsFactory reset is for lost passwords
Let us now how this goes. A reset should help here. Also try some of the other suggestions.
Here's my specs...
Operation Mode AP
Enable Beamforming
Enable Fast Roaming
- theoakLuminary
Channel 9 for 2.4G seems odd. I would set it to channel 1; especially, if no one else is around you and/or far.
Is it just the router or is there a satellite floating around too? Try using just the router and see what you get.
You are also using an Android phone ... you should have gotten an iPhone :smileysurprised: Oh wait ... wrong forum :smileyembarrassed: (joking)
Hi All, thx for the help.
The system is a 100% fresh, brand new setup so not going to do a factory reset.
Speed problems are on 5Ghz where there is zero interference from other Wifi radios.
Across ALL APs... 24 devices connect to 5Ghz while only 5 devices connect to 2.4 so it doesn matter but for those asking, Channel is Auto, no clue why it showed (9) but here's what it shows now...
WIRELESS SETTINGS (GENERAL)Region North America 2.4G Channel Auto ( 3 ) 2.4G Mode Up to 400 Mbps 5G Channel 36+40+44+48(P) 5G Mode Up to 866.7 Mbps - Retired_Member
WAaronLTek wrote:Hi All, thx for the help.
WIRELESS SETTINGS (GENERAL)Region North America 2.4G Channel Auto ( 3 ) 2.4G Mode Up to 400 Mbps 5G Channel 36+40+44+48(P) 5G Mode Up to 866.7 Mbps What firmware did you end up with?
