floredo1
May 01, 2019Aspirant
Orbi RBR50 AC300 slows down my internet
I upgraded my internet speed and Modem. when i connect directly to my Netgear Modem CM700, i am down loading at speeds of 300Mbps. I connected my Orbi router to netgear modem. Now my download speeds are down to 93Mbps. i am connecting directly to my Orbi router from my mac mini via ethernet. can someone help me figure out why? i did the whole unplug,hard rest thing and still running slow
Have you checked your cables that you're using? You're dropping just below that 100 mbps mark like your only using a 10/100 connection.
And I know we recommend checking speeds over a hardwired connection. Have you tested with any other hard wired (speeds) and wifi devices?
What firmware are you on?
- floredo1Aspirant
brand new cables cat 7 ethernet. i connectly directly to modem with mac mini and also laptop downloaded at 300Mbps. i tried several other devices on wifi when connected to Orbi still slows down to 93Mbps. Router FW V2.3.1.48
Are there any other devices connect? (managed, unmanaged switches, etc)
You stated you performed a factory reset on the Orbi?
Was the orbi ever getting faster than 100 mbps?
If you test lan to lan (laptop-orbi-mac) what speeds do you achieve?
What speedtest site are you using?
