marcgroet's avatar
marcgroet
ORBI RBR50 adds satellites as devices - not as satellite
Hi,
I am adding satellites to my ORBI RBR50 and they are recognised as devices.
So they are not recognised as satellites extending the wifi network.
Any tips?
Thanks,
Marc
  • plemans's avatar
    Is this in the app or in the browser GUI?
    I've seen a couple posts where the app displays them wrong but its fine in the browser
  • FURRYe38's avatar
    Be sure same FW version is loaded on the RBS as whats on the RBR.
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    marcgroet wrote:
    Hi,
    Any tips?
    Thanks,
    Marc
