Cheekymuppet's avatar
Cheekymuppet
Orbi Rbr50 and rbs50 keeps disconnecting
Hi
I have an rbr50 on the 2’d floor of my house, with an rbs50 (satellite-1) on the first floor and another rbs50 (satellite-2) on the ground floor. Satellite-2 connects to the router and initially has a good backhaul signal for about 12-24 hours, at this point the connection then goes to poor and finally disconnects completely.
I don’t understand a) why the connection just ‘deteriorates’ and also why satellite-2 doesn’t connect to satellite-1 in a daisy chain configuration because they are much closer together...
Any help is greatly appreciated as it’s starting to get very frustrating !!
  • I don't think that Daisy Chain is working as it should in this software (2.2.1.210). I hope Netgear will fix this in the coming releases.
    On the other hand, have you done a wifi scan around Satellite-2 to see the strangths of the backhaul signals coming from the Router and Satellite-1?
    Radio is tricky, it's not only the distance which affects the propagation of radio signals.
    • Cheekymuppet's avatar
      Cheekymuppet
      Thanks for replying...
      I’m using firmware 2.1.4.16 as I downgraded as many people said the latest firmware didn’t work with daisy chaining (should have stated this before).
      How would I scan for the backhaul channel?
      • ekhalil's avatar
        ekhalil
        Master
        If you have a Macbook it has a built-in scanner. If you have an iPhone you can download the Apple Airport app which has a built-in scanner (even if your don't have Airport routers). I'm also sure there are also other apps for Android and Windows.
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    Cheekymuppet wrote:
    Hi
      Cheekymuppet
      Hi
      The distance between the router and satellite-1 is about 15 to 20 feet, then satellite-1 to satellite-2 is about 15 feet.  The walls in the house are all solid brick walls, hence why they are closer.
      I've been using channel 11 for 2.4 Ghz network and 36 for the 5Ghz one, channel 11 is clear after doing a wifi scan, but just moved 5Ghz to channel 40 as thats clear. so will see if that helps.
      Thanks
        Cheekymuppet
        Sorry, just to add...
        When I reboot satellite-2, which this morning isn't connected, it will reconnect to the router, not satellite-1 (even though its closer) and will show a 'Good' backhaul status for about 24 hours, and then it just drops... I don't understand why it would be a good signal on reconnection but then without any of the devices moving the signal degrades nad then eventually disconnects...
