Bandito
Jan 12, 2018Luminary
Orbi RBR50 and Slow WiFi Problems with iOS Devices
I’ve been experience a very strange problem with slow WiFi speeds on my iOS devices for a few months now and was wondering if anyone might be able to point me to something to try to fix it. It se...
sloya1
Mar 03, 2018Initiate
I want to thank everyone for the feedback but none of the suggestions worked for me.
But all is not lost. This morning I continued to focus on the MacBook Pro since all other devices were working just fine. I was sucessful in fixing the problem with long delays or no response to websites. After several tries the fix ened up being a curupt wifi module. I corrected it by the following steps.
Click om the apple menu and select system prefference then network
Click on advance and selecte the wifi module and click on the - button and apply
Close the network menu and reboot your computer
After reboot go back to networks and click on advance nd click on the + button
From the menu select wifi and click apply
Next reconnect to your network and you should be up and running.
I hope this helps you becuase it saved me taking out the ORBI system
- FURRYe38Mar 03, 2018Guru - Experienced User
Glad you figured it out. Thanks for letting us know what the issue was and how you fixed it.
Enjoy the Orbi now.
sloya1wrote:I want to thank everyone for the feedback but none of the suggestions worked for me.
