Bandito
Jan 12, 2018Luminary
Orbi RBR50 and Slow WiFi Problems with iOS Devices
I’ve been experience a very strange problem with slow WiFi speeds on my iOS devices for a few months now and was wondering if anyone might be able to point me to something to try to fix it. It se...
Bandito
Mar 02, 2018Luminary
Thanks for the links to the other threads. Most of those problems sound different from what I’ve been experiencing. My system only seems to slow down throughput on iOS devices only. Other items continue to work as usual when this happens. It’s quite odd.
Time will tell if things will improve or not.
Bandito
Mar 14, 2018Luminary
Well, more time has passed and I’ve been able to learn a bit more about what is happening with my setup.
It appears that the Orbi router itself is stable and reliable; however, the satellites are very unstable and don’t appear to run correctly for even a full 24 hours. I found this out as I had an iPhone having connection issues and an iPad that wasn’t. I decided to see who was connected to what and found that the working iPad was connected directly to the router, while the iPhone was on one of the satellites. The iPhone would connect to the Internet, but experienced slow throughput and some connection dropouts. It did not, however have any problems communicating on the internal network. The backhaul showed it was functioning normally on the 5 GHz band, but whatever is causing problems appears to on affect the Internet connection.
I rebooted the satellite and verified that I was connected through it and everything worked well for the rest of the evening. When I tried things again this afternoon, the satellite was again causing problems. So, if Netgear can work out the problem with the satellites, I think we could have a good fast system, but until then, it’s causing nothing but headaches.
- FURRYe38Mar 14, 2018Guru - Experienced User
You might try this. Disable all Satellites and just use the Router for wifi for a while.
This is something you should contact NG support about and see if maybe you can get the Satellite(s) replaced.
- BanditoMar 15, 2018Luminary
Thanks for the suggestion, but if I disable the satellites then I don’t get signals in some areas where they are needed and I can’t relocate the router, so I’m kind of stuck. This was the main driving reason for upgrading to the Orbi system in the first place.
The fact that others are also experiencing satellite issues along with the apparent “recall” of the most recent firmware due to memory leaks in the satellites makes me feel like I’m not necessarily experiencing unique hardware problems with my satellites. So, in the meantime I’ll continue to monitor the situation and reboot just the satellites when necessary while waiting to see if Netgear can figure out what they’re doing wrong.
- BanditoMar 17, 2018Luminary
Well, this last time around, the satellite made it a little over two days before it crapped out again. The iOS devices clearly exhibited the slower connection speed and some stalling as well. One of the Windows PCs was connected to the router, but it also exhibited strange behavior. It’s Speedtest showed a slow connection at first, but then it gradually increased to where it got to full speed just before the download finished. Then it showed about half the speed for upload that it should have. After resetting just the satellite, the Windows PC returned to normal as well, so it would appear that there is some interaction going on between the satellite and the router that impacts the router’s performance until the satellite is reset. Who knows?
