sturt007
Dec 27, 2018Aspirant
Orbi RBR50 Device List Issues
Hi guys,
I have recently bought the Orbi RBR50 with a satilite device.
I am having a couple of issues:
1) If I go onto the device list on the Orbi app, I see the devices but if I click to pause a device, nothing happens! Device just continues to be connected.
2) Although I am connected to the internet via Orbi WiFi, every 10 mins or so my iPhone will say, you are not connected to the internet?
I have TPG NBN with a TP Link AC1200 router connected via Ethernet to the Orbi.
- ekhalilMaster1) Access Control does not work properly in current software. I’m afraid you need to wait until this is fixed in coming releases.
2) This second issue is likely caused by your TP-Link Router not being bridged. Please either set this ISP router is bridge mode, or if not possible then you need to change Orbi to AP Mode (I guess you have it now in the default Router Mode)
Good luck!- sturt007AspirantThank you for the help, that’s great.
With regard to the TP Link router, would you happen to know how I change this to bridge mode? Also, how do I change Orbi to AP mode?
Thanks:)- ekhalilMaster
What is the model of the TP-Link Router so I can check how to set it in bridged mode.
For Orbi, you can set it in AP mode using the GUI as follows:
