ericjooka's avatar
ericjooka
ORBI RBR50 dropping connections frequently
I have an Orbi RBR50 with one satellite. I have upgraded to V2.3.1.60 firmware. I have rebooted them both several times.
My Wifi connection is sporadically dropping without notice. It resets within 2 to 5 minutes, but I am unable to keep a persistent connection.
I did check the configuration, set the channel to 6, and restarted it all. It ran fine for a few hours, then started again.
I checked the log, and these entries were in there. Is it possible this is causing my problem?
[DoS Attack: RST Scan] from source: 88.99.103.29, port 8000, Wednesday, June 05, 2019 14:56:48
[DoS Attack: SYN/ACK Scan] from source: 209.86.93.209, port 110, Wednesday, June 05, 2019 14:47:32
[DoS Attack: RST Scan] from source: 88.99.103.29, port 8000, Wednesday, June 05, 2019 14:47:09
What can I do about this situation?
  • FURRYe38's avatar
    I would power OFF the ISP modem for 1 minute. Factory reset the XR router and power it off. Power ON the ISP modem and let it sync. Then power ON the XR router and walk thru the setup wizard again using a wired PC and a web browser.
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    Use Domaintools.com/whois to see where that IP address is coming from.
    • Sevwren's avatar
      Sevwren
      Tutor
      I myself get the matching ip's in my log like yours.
      88.99.103.29
      Many people have reported that ip as ddos attacks / portscans.  Reports range from June 2nd,  2019 up until 8pm CST June 11th, 2019
      https://www.abuseipdb.com/check/88.99.103.29
      Recently ones that show up that other users have reported as malicious are
      146.88.240.4
      45.67.15.69
      71.6.232.5 (portscan / vulnerability scan)
      136.243.60.85
      146.88.240.4
      172.104.242.173  (Italy based, Brute Force attacked reported from +600 users)
      184.105.139.105
      185.94.111.1 (7712 times from 550 distinct sources going back to 2017 in russia)
      Usually I disregard most DoS Attack: ACK Scan entries in my logs as well.  However I've had issues starting this past week where I can ping successfully to google's dns servers and live video connections don't get interupted, however any new attempt at web requests (port 80/443 etc) are unsuccessful.  Usually a reboot of my router will fix the issue.  There have been days though where the same problem occurs again anywhere from 30min to 2 hours later and I have to reboot our router/modem as well.
      My hardware
      Cable Modem Arris Touchstone TM1602A -> Netgear Orbi Model RBR50 running Firmware V2.3.1.60 -> 1 Satelite RBS50 running on firmware V2.3.1.60
      I don't believe it's any possiblity with my ISP as current live video isn't interuppted. (This is on a pc that has a hardwired connection to the Orbi router so I can rule out anything related to a wifi signal issue)
      My educated thoughts point to most likely either an issue with the Orbi hardware or something that's indeed being caused by an external source.
    • ericjooka's avatar
      ericjooka
      Thanks FURRYe38
      When I first installed the Orbi network, I had disconnect issues. Support was able to help me at that time. Now, I am on my own, since I did not pay for support. I tried to resolve it with a bunch of different recommendations, and nothing worked permanently.
      I had two choices. Pay for support and on a regular basis, spend time with support and reconfigure the routers. I chose the alternative - I have replaced my Orbi equipment with a new mesh system from a different vendor. It took minutes to set up and immediately solved the problem.
      Installing equipment that requires constant hand-holding and reconfiguration was not what I planned when I bought the Orbi system. Next time I pay big bucks for hardware, I'll read more reviews than the marketing pitches.
