Makiimochi's avatar
Makiimochi
Follower
Mar 29, 2020
Orbi RBR50 Hourly Disconnect
Hello! I just want to start off the post by saying I have zero to no experience with a lot of this so please bare with me and forgive me if I say anything strangely.
So I recently switched to AT&T as my ISP. I already had the Orbi from my previous setup and am using with the router we got from AT&T. Initially, I had the Orbi set to router mode but I was unable to access many websites, etc. I read up on how to solve the issue and so I switched my Orbi to AP mode but ever since, I have been experiencing a "No internet connection" on all devices every hour. This occurs at about the same time and for approximately five minutes. I work at home and it's been giving me a really hard time. Any and all help will be greatly appreciated!
  • FURRYe38's avatar
    What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
  • Hello, i have exactly the same issue. For weeks now. Since Corona i am working fulltime at home, constantly connected via VPN.
    Every hour at exact the same time all my connections got reset.
    I loose my vpn connection and internet connection
    On all my devices by the way.
    My setup
    RBR50    firmware V2.5.1.8
    RBS50 x2      firmware V2.5.1.8
    RBS50Y     firmware V2.3.5.32
    I am connected to the RBR50 via ethernet, which is wired via UTP6 to my cable modem.
    If i connect to the internet directly i have no disconnects.
    My VPN is a Cisco Anyconnect 4.3.03086
    My house is about 310 sq meters (3300 sq ft), distance varies from 12m to 6m, depending on the walls (thick brick walls, al ot of concrete and piping).
    Connections between them are good. Daisy chaining enabled (RBS50Y connects via one RBS50), roaming is working fine for other devices.
    Fixed 2.4 channel, there are 2 or 3 other signals but not that strong.
    Beamforming and MIMO and WMM enabled. Under Advanced Tab/Advanced Settings/Wireless Settings
    Disabled: Armor, Circle
    Had a factory reset and setup from scratch  since last FW update
    This should not be happening to a system that has cost me about 700$
    I am no n00b.
    Tried changing DHCP lease time via the debug page, but all my clients have reserved IP's, but no change in the disconnects
    • Retired_Member's avatar
      Retired_Member
      RBR50    firmware V2.5.1.8 = Bad firmware
    • FURRYe38's avatar
      Do both wired and wireless get disconnected?
      Only VPN?
      You can try to update your system to v16.
      https://community.netgear.com/t5/Orbi/RBR50-RBS50-Firmware-2-5-1-16-Update/m-p/1897955/highlight/true#M89460
      Update using this process:
      https://community.netgear.com/t5/Orbi/RBR50-RBS50-Firmware-2-5-1-16-Update/m-p/1901692/highlight/true#M90127
      My setup
      I am no n00b.
      • wimmme's avatar
        wimmme
        Tutor
        The modem is a Motorola / CV6181E (DOCSIS).
        Disconnects are both wired, wireless, and so the VPN also .
        2.4GHz is on channel 1
        5GHz is on channel 36
        Changed them all, to no avail; but some interference should NOT cause network disconnects, certainly not on the laptop i am using wired tot the RBR50.
        I will try to update to that new version 2.5.1.16 this evening.
        Factory resetting and reconfiguring is a real PITA, since I have 50+ devices on my network, all with fixed IP's.
        But i will and report back
        Tnx for the feedback guys
