E14dtl's avatar
E14dtl
Follower
Aug 11, 2020
orbi rbr50 how many devices does it holdbi
how many devices can I add onto my orbi.
I have a virgin media hub that holds 15 devices( currently has 30 on it).
I bought the orbi hoping that I can split the devices between the 2 routers.
my question is, I  am hoping that I dont need to add the orbi onto my current router.
Am i right in thinking that I dont need to, or am i expecting too much
  • FURRYe38's avatar
    https://kb.netgear.com/31097/How-many-devices-can-my-Orbi-system-support
    Having two routers online is NOT recommended. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
  • CrimpOn's avatar
    CrimpOn
    Users have reported having more than 100 devices on an Orbi system.  There are routine reports of more than 50.
    In a technical sense, the Orbi design allows for about 250 potential IP adddresses and has table space for 65,000 IP connections.  (A single web page may open hundreds of connections while loading the page. They close automatically shortly after.)  My 30-odd devices are now using 1,107 sessions out of the 65,000 possible.
    FURRYe38is correct that splitting devices across two routers is not recommended.  Either use one or the other as a "router", but not both.
