darryl12123
Jan 25, 2020Aspirant
Orbi RBR50 issue with Sonos Playbar
Hi guys,
Since this morning I've issues with my Sonos playbar. It won't connect over wifi with my Orbi RBR50 which is setup as AP. It was working fine for months. I've tried everything, factory resetting Sonos and Orbi, nothing helps. I updated the firmware on Orbi to the latest (2.5.1.8). In the release notes it says that this firmware version solves compatibility issues with Sonos. But clearly is still have issues.
Does anyone else have issues with Orbi and Sonos?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What channels does the Sonos work on. Does it broadcast its own wifi signal any?
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Has a factory reset and setup from scratch been performed since last FW update?
I would contact Sonos Mfr and ask for there help and information if any of the suggestions don't work for you.
- darryl12123Aspirant
At the moment I've switched off the satelite to rule out it isn't the problem.
Forgot to mention earlier but I said that the Orbi is setup as AP, so the main router is a Nighthawk. I switched on 2.4ghz (on which Sonos works with) on the nighthawk just to test if Sonos was the problem or the Orbi. I factory reset Sonos and connected it to the nighthawk and it worked without any issues! Reconnected again to the Orbi and it won't work wiresly. It does work with an ethernet cable but obviously I want it wiresless.
So the problem is at Orbi, not Sonos.
Be sure to disable any wifi on the NH router. Try some of the suggestions meantioned for Orbi.
