theerdman's avatar
theerdman
ORBI RBR50 keeping old 5g password
I have completely reset my device to factory and have gone through the initial setup in hopes of clearing any cached credentials in the device.  Unfortunately, after the complete reset i went to connect to the SSID-5G network and it had retained the password from the previous session.
I have been unable to reset or clear the password that is different between the 5ghz and 2.4ghz networks for the same SSID.  How do i flush the cached credentials so i can leverage the same password for both channels?
Thanks,
RD
Hardware Version   RBR50
Firmware Version   V2.7.4.24
  • CrimpOn's avatar
    CrimpOn
    If the Factory Reset is done properly, the Orbi WiFi will power up with the credentials that are printed on the product label (bottom of case).
    The WiFi SSID will be the letters "ORBI" plus a two digit number and will be the same for 2.4G and 5G WiFi.
    The WiFi password will be some combination of common words.
    This is not what happened?
    • theerdman's avatar
      theerdman
      That is not what happened.  The resets took place and all of the expected settings were flushed EXCEPT the password for the SSID-5G channel.
      I dont see anywhere that i can actually just change that channel password so i am unsure how to clear this or update it to something new.
      Thanks,
      RD
      • CrimpOn's avatar
        CrimpOn
        Perhaps I am not understanding.  After the factory reset, the Orbi was broadcasting the WiFi name (SSID) that was printed on the label, but the password was not the password printed on the label?
