TimdF's avatar
TimdF
Initiate
Feb 21, 2022
Orbi RBR50, no connection with satelites anymore
Since 1,5 year I use an Orbi system with 3 satelites, never had any issues.
But out of the blue (I have not changed anything) I only have connection via the router and the 3 other satelites are gone in the netwerk.
Tried to reboot and reinstall but he cannot find the satelites anymore.
Any tips how this might be possible and how to reinstall again?
Thanks!
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the Orbi AC products. Most of the people who watch that forum are more likely to have experience with Orbi (WiFi5 RBK Series). Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi/bd-p/Orbi
    Thank you.
  • plemans's avatar
    what firmware is on the router?
    Firmware on the satellites?
    What modem/gateway is the router connected to?
    Are you re-syncing the satellites?
    what error do you run into when re-syncing?
    • TimdF's avatar
      TimdF
      Initiate
      Thanks! Hope I can answer them with my knowledge;
      - The firmware on the router is V2.7.3.22
      - Firmware satellites I can not see anymore, the app does not recognize them (see attached)
      - Connected to the router of my provider (in bridge modus) via lan, lan and wifi via the Orbi router is working
      - Not sure how I can re-sync, I tried via the sync bottom on the back of the units
      - The app does not recognize the satellites anymore when I search for them
