dennisbaron's avatar
dennisbaron
Follower
Nov 21, 2020
orbi RBR50 not connecting with motorola mb8600 modem
Tyring to install a new Motorola docsis 3.1 modem (MB8600) and xfinity says it's recognized and onine but Netgear ORBI rBr50 won't bond it with. flashing green LAN light on modem instead of blue. Netgear works fine on old Arris Surfboard, but not on the new modem which supports gigabit internet speeds. any ideas?
  • FURRYe38's avatar
    Did you power OFF both modem and RBR first, the power ON the modem and let it sync then power ON the RBR?
    Besure your using good quality LAN cable. CAT6 is recommended.
    Possible a reset maybe needed on the RBR and walk thru the setup wizard.
  • CrimpOn's avatar
    CrimpOn
    Perhaps it is worth definining "bond" in the context of this post.  The MB8600 modem has the capability to "bond" more than one gigabit port together to provide more than 1GB internet to the customer.  RBR50 Orbi cannot do this. This Orbi has only one ethernet WAN port.
    The MB8600 setup guide mentions a number of things that "blink" or turn blue.  Exactly which of these things is flashing green rather than blue?
    https://assets.ctfassets.net/0dyo76hkwr49/5IFchJqd2g26YsoagOq8E0/6262be4ce4e8d6d853dbc8c6b11ca2e2/27745-EL_rev_D__MB8600_QS_092217b.pdf
