awhipple11's avatar
Apr 20, 2021
Orbi RBR50 Not Connecting
I have the RBR50 mesh system and it will not work properly after working perfectly for 2+ years. I've done the reset 5+ times and still have no luck. It says it's connected but when I go do a speed test it says its at 2.0 Mbps. No webpages will load, apps, etc.
Any suggestions or is the system dead?
Thanks!
  • FURRYe38's avatar
    Press the back reset button for 15 seconds then release.
    https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
    Thanks!
    • awhipple11's avatar
      awhipple11
      Tutor
      Yes, I have done a factory reset probably 5 times today. It reconnects but the internet is still not functioning properly.
      • mrputtputt's avatar
        mrputtputt
        Tutor
        you may have same problem as me. i just bought a new one to remove the possibility of any hardware issue on any machine i have. oddly while i cannot go to the router via 192.168.1.1, everything is connecting accordingly.
        That's why i spent hours (3 hrs at one point) troubleshooting this with mulitple restarts of ISP modem & router. And doing a new "setup" via mobile app before 30-30-30 reset and one 15 sec reset push also.
        Very disappointed it only lasted 2 yrs. But it is what it is and I'm hoping the replacemeent lasts longer since I have no AX devices to leverage a new router for and start over in a sense.
