msanand's avatar
msanand
Initiate
Apr 04, 2020
Orbi rbr50 router Wifi does not work but satellites do
Hey all - I’m having what I think is a unique problem. I have a RBR50 router with 2 RBS50 satellites. Hooked up to an Arris modem connected back to Comcast. My iPhone and my kids iPads simply cannot get any connectivity when those devices are closer to the main router. When those devices get moved to another room and presumably connect to one of the satellite they can get online fine. In fact I am connected via one of the satellites and typing this on my iPhone :) One thing to note is that those devices do connect to the WiFi network from the router and show a strong signal in fact. It’s just that no websites load up. Another thing that’s weird is that there’s other devices, particularly my Sonos speakers, that are connected over WiFi to the router and they function no problem. It’s just these iOS devices that do not seem to be able to
connect to the internet when they are in close proximity of the router. Any help or pointers would be really helpful. Thanks in advance!!
  • What Firmware version is currently loaded?
  • FURRYe38's avatar
    • msanand's avatar
      msanand
      Initiate
      Thank you so much for the advice!! I had to set 20/40Mhz Coexistence to 40Mhz only and set Short preamble instead of Long preamble. Rebooted and the dead zones with the iOS devices are gone! Thing of the past. Thanks a lot!
      • FURRYe38's avatar
        Good to hear.
        Please mark your post thread and solved.
        Enjoy. :smileywink:
