Vickyobee
Sep 03, 2021Aspirant
Orbi RBR50 Satellite dropping connection
Hello every 1
I am having a connection prob with Orbi Satellite..It drops off the connection randomly and then comes back after 5-7 Mts and this is happening several times a day
Well all this started a few days back..
Model ........RBR50
Firmware ...2.7.3.22
Tried a power off and also factory reset..
still no luck..
Tried keeping the Router and Satellite just a few feet away..
Also tried to use Ethernet cable..
have no idea what previous ver was there earlier..
is there some thing to do with the NEW FIRMWARE
pls help..Much thanks in advance
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteTry downgrading to v104 on the RBS then RBR...
- VickyobeeAspirantHi thanks
It's Penthouse
Distance between RBR and RBS IS ABOUT 20 FT.
Ground floor and First Floor
How ever the prob remains
Even if both are at Any distance apart.
Tried from 5 ft to 40 ft
Also have the same connection drop Prob while using ethernet cable
About downgrading to lowrr VER..
Where do I get the old firmware from..
Much thanks- FURRYe38Guru - Experienced User
20 feet is too close. 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
What ethernet cable are you using? Be sure it's good quality LAN cable. CAT 6 is recommended.
Is the RBS directly connected to the back of the RBR or is there a LAN switch in between the RBR and RBS?
