jefferis's avatar
Sep 19, 2024
Orbi RBR50 Satellite will not connect
Having trouble with a satellite for this   RBR50     First of all,  clients cannot connect to the satellite's wifi signal with the same password as the base.
I restarted the satellite and it lost connection to the base. I followed sync instructions but no joy.  I then removed it from the orbi  and tried to add it as a new satellite, but it will not sync.     Help! Please.
  • FURRYe38's avatar
    Turn OFF all other working RBS.
    Try a 30-30-30 reset on the one non working RBS. Then try to re-add it to the RBR using the RBS add satellite funtion on the RBRs web page.
    What FW version is on the RBR and any other RBS?
    Was the system updated recently? RBS need to be updated first before the RBR is.
