nickduts's avatar
nickduts
Orbi RBR50 Separate wifi bands
How do I separate my 2.4 and 5 GHz bands on my Netgear Orbi RBR50 system without them resetting again. I have done some research and found out how to separate them however after about 10minutes the 5ghz said disappears and only the 2.4ghz one remains and it is the only one is being used. How do I prevent this from happening (How do I make sure they stay separate and not revert back to how they were before I separated them automatically)
  • Yes and no. Sometimes it switches in the same place and my link speed drops significantly and sometimes when I move. Honestly, the reason I was trying to fiddle with the bands is to maintain a higher and constant link speed. I feel like I may have solved this issue though, I went into the advanced settings and I've enabled 5ghz SSID broadcast, my phone has been on the 5ghz band since and my link speed is much better now. Thanks for the help and if you have any other ideas or find another solution, please do let me know.
  • CrimpOn's avatar
    CrimpOn
    The short answer is, "you cannot."  The long answer is: "What are you trying to accomplish?"  There must be some reason to want to do this.
    If the answer is, "I demand that my WiFi have separate SSID's for 2.4G and 5G so that I must keep track of which WiFi each of my devices connects to", Orbi is not the correct product.
    • nickduts's avatar
      nickduts
      I'm just trying to ensure that I have the highest speeds coming into my devices based on what they can use for example: My phone supports 5ghz and for some reason Orbi only puts it on the 2.4ghz band and I can't use the full potential of my phone or my router because my router isn't assigning the fastest band possible to my phone even though signal wise, the signal strength is fine with both hands.
      • CrimpOn's avatar
        CrimpOn
        The accepted understanding is that the device decides which WiFi channel to join, not the router.  My Sony Xperia, for example, always connects to the Orbi at 5G.  (as does my wife's iPhone & iPad, my Galaxy Tablet, my 2.4G/5G WiFi cameras, etc.)  I suspect there is something else going on which is affecting your phone.
        Have you tried "forgetting" the Orbi WiFi, locating the phone close to the Orbi and then searching for WiFi?
        Mind sharing which brand/model of phone this is?
