brightball
Jul 29, 2020Aspirant
Orbi RBR50 speed seems to be degrading over time
I've had my Orbi RBR50 and 1 satellite for a little over a year now (March 2019). For most of that time, everything seemed to be working fine but over the last 3 months we started noticing problems on our home network (wired and wireless).
Here's a summary of everything I've attempted to test and remedy the issues:
My internet service with Spectrum is the 200mb plan which typically performs at 220mb in on Speedtest.net. When running these tests either via a computer on the network, hardwired, wireless or via the Orbi admin speed test, these numbers were consistent. In the last 3 months, I would see it top out around 95mb.
Following guidance found elsewhere on this forum, I plugged my computer directly into my cable modem to see if it was an issue with the modem but I was able to get full speed. I used the same cable that the Orbi was using to connect to the cable modem, so I had a strong sense that it wasn't a problem with the CAT 5e cable but just to be certain I repeated the test with a CAT 6 cable and saw the same results.
Next, I took a gigabit switch that I had available which has connection indicator lights on it to show whether it is 1000 or 100. The WAN port on the Orbi shows 100 every time. The LAN ports and every other device involved shows 1000.
Following some other advice in the forum, I tried the factory reset process on the Orbi but with no help. Because I'm working from home and needed to see this resolved I ended up ordering a wired-only Gigabit router to support the hardwired devices on my network and it's working fine.
My intention was to switch the Orbi into access point mode afterwards to just let it support the wifi in my house. After making this switch the Orbi is topping out at 45mb on Speedtest (either via the built in test or with a device connected to the Wifi when standing next to it).
Does anybody know what could be going on here?
Possible that the RBRs WAN port is faulty if the connection status reads 100Mpbs. IT should be 1000Mpbs.
You may want to contact NG support to see if they can help you or see what your options are.
What is the Mfr and model# of the ethernet switch in the configuration?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Not seen on Orbi AX.Try disabling the following and see:
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Has a factory reset and setup from scratch been performed since last FW update?- brightballAspirant
FURRYe38 wrote:What Firmware version is currently loaded?
v2.5.1.16
Cable Modem
Hitron Technologies, Inc, DOCSYS 3.1 eMTA, E31N2V1
The wired only router that was just added is a Ubiquiti EdgeRouter 4 ER-4
and the switch connected to it is a Netgear ProSAFE GS108PE.
The Orbi has been tested while plugged into the Cable modem directly, directly into the EdgeRouter and into the switch. A computer plugged into the switch speedtests at the maximum 220. The Orbi is currently plugged into the ProSAFE switch and the indicator light is the Orange 100.What is the size of your home? Sq Ft?
I'm actually not concerned about the Wifi performance. The Wifi performance mirrors hardwired performance that I'm seeing through the Orbi and I'm testing within 5 feet with no obstructions. The satellite is currently turned off.Try disabling the following and see:
Just applied and retested. I don't see any noticeable difference.One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026Just tried it. No noticeable effect.
Has a factory reset and setup from scratch been performed since last FW update?Yes. 4 days ago.
