Flo_Amsterdam
Dec 19, 2023Aspirant
orbi rbr50 wont reset
HELP
om losing it, almost smashing my orbi through the house...
one moment everything is fine, next moment no internet connection...
i've tried every possible way to reset the orbi router, but it never shows an orange color, just red flashing, then green steady at the power button.
the top ring is continues flashing white.
i have just my phone with 4g nothing else, i've read some things about how to reset with new firm stuff, man I have no idea what im reading, i have no IT experience and no im losing my head over this.... this stuff costs a lot of money, and now after 2 years, it stpped working and i cant to make it work again....
Please, somone, help me get this thing working again.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Can you access the RBRs web page at 192.168.1.1 with a ethernet connected PC and web browser after pressing the reset button for 15 seconds then release. Try this with the RBR disconnected from the ISP modem/ONT.
- Flo_AmsterdamAspirant
where can I find what version its on?
it has been working fine for the last 2 years with cat6
i dont even know if there was n update, one moment it was online, was about to play xbox, and then the next sec it was offline, and wont come back online...
just had everything off, then turned on the modum and waited to be fully operational.
then plugged in the orbi, nothing, just flashes white ring on top....
tried to reach the page but can't.... says i have no conection
i pulled the cable from the orbi, and put it directly into my pc, and then the pc has internet....
so everything is working, but somehow the rbr50 doesnt allow the connection....
