WDLuisi's avatar
WDLuisi
Orbi RBR50
Is there a way delete multiple devices from the device manager?  I rent my property and have a guest network.  Every time I have a renter all of their devices get added.  The app only allows me to delete one device at a time.  Is this what I have to do?  One at a time.  If I do nothing and just ignore the list, does the device list grow to infinity without any impact on the performance of those devices that are active?  It takes quite a bit of time every time I look at the list to delete these devices.  Imagine renting to 10 people, and each of them have a smart phone, computer or iPad, watch?
  • While connected to the orbi's wifi, use a browser to connect to the router's IP address.  Sign in to the orbi with
    Username: admin
    and that account's password
    You will NOT need to login to your Netgear account.
  • CrimpOn's avatar
    CrimpOn
    Despite numerous reboots, my Orbi kept a record of every device that had ever been connected.  I had 36 active devices, and 124 devices total.  In the web interface, almost 90 devices were in the Access Control table:  "Allowed devices that are not currently connecfed".  With the web interface, it is quick to delete any that no longer apply.  In the "app", it is one-at-a-time. (ugh)
    A Factory Reset, of course, wipes out EVERYTHING.  For a rental property, this might not be so bad. Hold the reset button down for 10 seconds and everything goes back to the credentials printed on the labe.
  • I have access control enabled and when I use the web interface, I can see unconnected devices that were connected in the past on the access control screen. You can check/select multiple devices and delete them from there.
    • WDLuisi's avatar
      WDLuisi
      That's great news thanks.  I'm assuming I need to login to my Netgear account.  Can you tell me the steps I need to take to do this?
      • --Chuck's avatar
        --Chuck
        Guide
        Username: admin
