MrToadsWildRide's avatar
Mar 29, 2019
Orbi RBR50/RBS50 Firmware Version 2.3.1.44 constantly dropping wifi connections to iphones/ipads
Updated my RBR and 2 RBS satellite (also have 2 RBSK outdoor satellites that did not update) a few days ago.  Worked fine until yesterday and now none of our iphones or ipads will stay connected for more than a few moments.  Most of IOT  wifi connected devices in the house are fine as is my desktop.  Anyone else having or have had this problem?
I can renew the lease on the iphone wifi and it will connect for about 30 seconds but then it gets booted off to LTE.  All phones in the house having he same issue.
Solutions?  Thanks
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    What WPA security modes are you using?
    Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    Set up some IP address RESERVATIONS on the RBR for your devices as well.
    • jsturess's avatar
      jsturess
      Apprentice
      Seems like we are some people now that have this problem and no solution in place
      Above post dosent help, have tried them.
      • jsturess's avatar
        jsturess
        Apprentice
        MrToadsWildRide do you also have problem with gui presenting connected devices? switching between wired/2.4/5? and also which it is connected to, changes from router to one of the satelites and so on?
        You have to look for some minutes to see this behavior.
  • FURRYe38's avatar
    Any progress on this?
    Solutions?  Thanks
    • jsturess's avatar
      jsturess
      Apprentice
      My wifi also still drops but for all devices, see attachment. Today the "connection type" and connected orbi" seem so work, it dosent chage from wifi to wired and so on under connected devices. What I have changed since last time is "transmitt power controll" to 100% for both 2,4 and 5GHz, seems to stable "connection type" but it still drops wifi.
      • FURRYe38's avatar
        Have you updated to v48 and done a factory reset and setup from scratch after the update?
        Try enabling or disabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
        Test system with all cameras turned off.
