Krisco1234's avatar
Krisco1234
Initiate
Mar 05, 2019
Orbi RBR/RBS50 Firmware 2.3.0.32 upgrade
I just successfully manually upgraded my Orbi satellite RBS50 to the newest firmware version 2.3.0.32 (from 2.2.1.210) . Unfortunately when I tried to do the same with my router I got the message:"The firmware file is incorrect. Please get the firmware file again and make sure it is correct firmware for this product".
The system as a whole works fine despite different firmware versions for RBR50 and RBS50. Any idea anyone pls how to fix the issue.
  • CrimpOn's avatar
    CrimpOn
    Did you first upgrade the RBR50 to 2.2.1.212 before attempting 2.3.0.32?  That step is required.  There was a size limit in every Orbi firmware prior to 2.3.0.32 that is no longer adequate, so Netgear released a temporary version (212) just to remove the size limit.
