dnh3155's avatar
dnh3155
Tutor
Feb 26, 2019
Orbi RBR/RBS50 Firmware Updates
I just did a firmware update to 2.2.1.210.  No matter where I go in the app, it says that this is the latest version. I read that there is a new firmware version, and that I have to update to 2.2.1.212 to get it. Obviously, I’m two updates behind. How do I get to the latest?
  • There was indeed a new firmware release earlier today, but Netgear has since pulled it as some users have given feedback that certain firmware files are not working properly. I suppose once the new firmware is up on the Orbi support downloads page again it'll also be available for updating via the Orbi app.
  • FURRYe38's avatar
    Please be patient while NG handles the new FW. It was posted and also v212 was needed to update the RBR to v32 as well. Changes are being made so keep an eye on the forums and the download site. Some system may have updated automatically as well. Keep an eye on your systems.
    • dnh3155's avatar
      dnh3155
      Tutor
      I am having trouble updating rbr50/rbs50 to latest version. I have tried to load 2.2.1.212 on satellites first through orbilogin manual, but can’t do it. Obviously, I’m missing something.
      Thanks
      • FURRYe38's avatar
        Satellites don't need v212, they can go directly to v32 first. Upgrade the satellites first. When those are finished, upgrade the RBR to v212 then v32.
        If you need to factory reset the RBS re-sync. then have a wired LAN PC connected to the satellite and update the FW there.
        Thanks
