IamMightyThor
Apr 07, 2017Guide
Orbi RBS50 no 2.4GHz connection to router
RBR50 & RBS50 Firmware V1.8.0.6 - Router and Satellite Came across this the other day, I logged into the RBS50 to see what I could see, I noticed that the image on the main page showed the statu...
Daveapatton
Apr 08, 2017Guide
I'm having the exact same problem except my 5 GHz won't connect. I've also posted my problem in this discussion room-keep an ion my post to see if anyone gives us good advice.
Look at the picture I said when I search for networks:
Daveapatton
Apr 08, 2017Guide
Forgot to mention, the name of my network is Patton - you can see below my network, the 5 GHz signal will not join my signal.
- IamMightyThorApr 08, 2017Guide
Not sure why, but pictures aren't displaying.
- DarrenMApr 10, 2017Sr. NETGEAR Moderator
Orbi has band steering so it will put the device on the best network did the older device connect to the 2.4ghz?
DarrenM
