IamMightyThor
Apr 07, 2017Guide
Orbi RBS50 no 2.4GHz connection to router
RBR50 & RBS50 Firmware V1.8.0.6 - Router and Satellite Came across this the other day, I logged into the RBS50 to see what I could see, I noticed that the image on the main page showed the statu...
rhester72
Apr 11, 2017Virtuoso
I quite promise that it is indeed 5GHz only. It runs on the upper channels of that band, leaving the lower channels for 5GHz client connectivity. There is no 2.4GHz backhaul whatsoever, as it isn't fast enough (and there's no dedicated radio for it).
Rodney
JMU1998
Apr 12, 2017Luminary
If the 2.4GHz is turned off on the base/main Orbi unit will it also turn the 2.4GHz off on the satellite as well? I ask because I do not have any old legacy devices so I turned off the 2.4GHz on the main Orbi but the satellite shows both bands in blue and just 2.4GHz says no connection in blue it should not be there correct? Is there a way to turn 2.4GHz off manually on the satellite itself?
