IamMightyThor
Apr 07, 2017Guide
Orbi RBS50 no 2.4GHz connection to router
RBR50 & RBS50 Firmware V1.8.0.6 - Router and Satellite Came across this the other day, I logged into the RBS50 to see what I could see, I noticed that the image on the main page showed the statu...
DarrenM
Aug 03, 2017Sr. NETGEAR Moderator
Is there a setting in the phone to disable the 5ghz because right now you can not force orbi to use 1 band.
DarrenM
CMCHARRON
Aug 03, 2017Aspirant
Unfortunately there is no way to force the phone to connect at a certain band. What I did is hooked up the old router again and changed the SSID of the 2.4 gigahertz to match the new orbi SSID and password. Then I was able to connect my phone reprogram the outlets disconnect all that power back on the ORBI and everything is fine
