Crispin123's avatar
Aug 24, 2021
Orbi RBS50 reboots everyday
I have an Orbi mesh network...  and it has this reboot problem  -  approximately every day it rebots.   Recently I internet supplier upgraded their router  and I hoped that would solve the problem  ... and for 6 days it worked without rebooting.  Now it is back to its normal behaviour of rebooting at random times at least once a day.
I have read the forum -  and if you have this problem Netgear has replaced the product ...  My problem is that I bought this system in 2018 and I am out of warantee...  so I called Netgear to ask about sending it in to them for repair.  But no:  Netgear do not repair their product -  and the suggestion is that I should throw this product away and buy something new...  and the person on the phone could help me make a choice of their new equipment.
Personally I find this outrageous.   This is expensive kit -  clearly there is a design fault that leads to this rebooting issue - but netgear wash their hands of it
  • Just a small update...
    On my ISP router I have enabled DMZ mode that points to the address of the Orbi (192.168.1.10)
    On the Orbi I have set it up as a router -  and it shares adresses in the family of 10.0.0.1  etc...
    The system has now been running 6 days without a problem and without a reboot.
    I have also enabled the wifi network on the ISP router (as a backup in case of problems) - and this does not appear to disturb anything.
    On the ISP router I have also attached a computer on a fixed address (running linux) that I need to log into from outside - and this continued to work -  I have also an internet telephone on the router of the ISP.
    The key appears to be using a fixed address for the Orbi - and running the Orbi as a router.
    Many thanks to FURRYe38 for their insight.
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    Armor, Circle, Traffic Meter.
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
    • Crispin123's avatar
      Crispin123
      Tutor
      Thanks for the useful information
      Firmware V2.7.3.22  (GUI language version V1.0.0.375)
      The router supplied by the ISP is a Icotera Model: i4850-00.
      The problem I have is that the walls are ~ 1 m thick stone and the Orbi satelites can talk through the wall when they are placed each side...
      The reboot usually happens when I am connected to the server unit -  and happens during video calls - and this makes it very annoying.  I have enabled the WiFI on the Icotera router with a different Wifi name -  and this works without problem [i.e. never hangs]  so I can join that network if I am making a critical video call.
      Each firmware update I hope that Netgear would solve this problem.    I have tried many variations to try and find a solution to this continuing rebooting  - but so far I have failed.  I am not alone with this problem and I would have thought that Netgear would either offer a hardware fix -  or fix the firmware -  instead their service department say that I should throw it away and buy something new : unbelivable.
      I will go through your list of suggestions ...   but I fear that there will be no magic solution
