Stallion69
Dec 02, 2020Tutor
ORBI RBS50 Satellite
One of my satelittes keeps pulsating white and will not stop. I disconnected it for a week because i was remodelling my office. I rehooked it up and it won't go online. I have both satelittes hooked up with ethernet wire back to the RBR50 router. Only one satelitte shows online. I tried to reset and sync the satelitte and still no luck. Any suggestions?
Are the RBS directly connected behind the RBR or is there a ethernet switch in between?
Try swapping locations around with the other working RBS to see of the one will work there...see of the working one does same thing at other location.- I am currently running Firmware V 2.7.0.70.
I have both satellites hardwired directly to the back of the RBR50 router. Ran fine for over two years. Now one RBS satellite will not connect.
I will try to swap them and see if that does anything.- FURRYe38Guru - Experienced User
Please downgrade to v16:
I foudn that v2.6/.7 versions of FW cause problems when RBS are ethernet connected.
