Seattlites's avatar
Seattlites
Orbi refuses to change status for blocked devices
I have the latest firmware for RBR50 and RBS50 and generally everything seems to work as well as could be expected, except for two of three new devices I've added to the network over the past two days.  After disabling Access Control (to make the initial connection process a bit easier) and then re-enabling it, two of the three devices I've added continue to be blocked.  Neither the admin console, nor the Orbi app seem to be able to unblock these devices, or, in some cases the status will change to allowed and then revert back to blocked.
The new 2.4G devices I've added are:
1) WyzeCam Pan (I already have a 'regular' WyzeCam connected wirelessly) - cannot change status to allowed
2) Smart Outlet #1 (this outlet is not blocked)
3) Smart Outlet #2 - this outlet has a poor connection, but functions just fine if I disable Access Control
Your thoughts greatly appreciated.
  • Hello Blanca.  Sorry for my delayed reply as I was out of country for a couple weeks immediately following my original post.
    In any case, the situation appears to have resolved itself.  I can't say what caused it or why it self-resolved after many, many ill-fated attempts to get the devices back into 'Allowed' status.
  • FURRYe38's avatar
    What browser are you using? Try using IE11, FF or Opera to see if any changes are seen here.
    Do you see any error messages? What is the visual behavior in the UI that the controls are not working?
    There have been some reporting problems with access controls.
    Christian_R
    Blanca_O
    • Seattlites's avatar
      Seattlites
      I use FF most of the time.  Just for kicks, I loaded the admin console with IE 11 and re-enabled Access Control (which I had disabled overnight).
      • The new WyzeCam says allowed (I did not change it), but I'm not sure I believe the router will keep the setting as it seems like it flipped over this past weekend.
      • The second outlet is still blocked and will not change to allowed. Again, it has a weak signal, yet it is otherwise connected if I disable Access Control.  If I attempt to recitfy the situation via the Orbi app, it gives me a message about "try again later" and last night I tried it several times in a row and it actually caused the router to reset or something similar...I lost all connectivity for a few minutes.
      I probably have to disable Access Control for now, but I dislike that solution.  Perhaps a fix in the next Firmware update is in order?
        Seattlites
        I will also say that the names of some of the allowed devices (no changes to those) seem to change.  For example, multiple Sonos speakers that usually say "SONOSZP" now reflect different names, two of which say "Unknown."  Not sure what's happened with the allowed device list, but there seems to be a bug.
